Strange behavior of shortcuts for Plugin: Note Tabs
If this is a bug report, please create it on GitHub instead. Follow this link:
on
Joplin 3.5.9 (prod, win32)
Device: win32, 13th Gen Intel(R) Core(TM) i5-13500H
Client ID: 3cfda04f19714c8eb4698a10767329db
Profile Version: 49
Alternative instance ID: -
Revision: 4afac41
Backup: 1.4.3
Freehand Drawing: 3.1.0
Note Tabs: 1.4.0
Quick Links: 1.3.2
I've created shortcuts for Plugin: Note Tabs to switch between tabs. Following the instructions from the plugin author, I exported keymap-desktop.json, added the code for the shortcuts, and imported it back to Joplin. The shortcuts, Ctrl+Tab, Ctrl+Left, Ctrl+Right, worked well until I used other shortcuts, such as Ctrl+C and Ctrl+V. After that they stopped working. Interestingly, this behavior is observed only if I use the Rich Text editor. When I switched to the Markdown editor, the shortcuts worked just fine. Is it a bug?
