Stop Auto Scrolling in Split View?
Sometimes the autoscrolling/sync is not helpful in the split view. When I have large images in the document, the views do not align well at all. Is there a way to turn off the scroll syncing completely? Can this easily be added or via a plugin?
Umm.. This sync scrolling feature is clever enough. When your mouse is keep staying on the markdown editor, the sync-scrolling speed is depend on the content of markdown editor. So, you can just move your mouse to the render viewer side and then scroll again. You'll find it's work!
It don't work for HTML notes – it scrolls the right view, when scrolling invisible element. So, how to disable it?
