Start minimized to tray?
Hello Developers,
it is possible to start Joplin minimized to system tray, is there a startup option?
I have the Linux client.
If not, this would be a great feature
thx for your great app
The icon of joplin is in the notification bar of XFCE4 for example, just tick the checkbox in the global options
Hello foxmask,
thanks
yes the icon is in the system-tray of KDE also.
My question was: It is possible to start Joplin directly minimized to system-tray/notification-bar?
currently, no.
you may ask to laurent if a feature request can be done for that.
no sure
last thing, you can automatically start software with your opened KDE session. If you do so for joplin, then Joplin will be started and present in the systray
I am new to the forum, but I would like to be on more person requesting the option of having Joplin minimized to tray. What’s the next step?
I run Linux Mint on Cinnamon.
there is (almost) something like that here
KDE4 had something to start a program minimized (I don’t know about “start in tray”), KDE5 does not have it anymore.
I don’t know how the X-Server can do it.
Alltray didn’t help in Autostart, because alltray stays itself in tray
Other application can do it by themselves; QOwnNotes e.g.
I tried the workaround in Windows but it doesn’t work!
Could anyone confirm that the workaround works in Windows 10 (October Update)? I can’t make it work!
i would love if this could minimize to tray in both x.org and weyland on KDE plasma 5. PLS PLS PLS
