Hello, thanks for Joplin, it's awesome.
I was looking after latest releases with some fixes I want and... well, I found out that Joplin uses a weird versioning system:
Yikes! It's hard to understand how this goes!
My proposal is to use a standard versioning system that helps everybody to understand what's going on. It may be a common standard or something made specifically for Joplin if those are not enough. Some standards I know and would probably fit:
semver. Widely adopted. It has the
symbol to indicate a version that has the same precedence, but has different build metadata. It might help for those android, ios, server variants... although I think that just sticking to alpha, beta, and rc should be enough for that case. - PEP 440. These days I tend to prefer this one, as it covers cases not covered by semver, which is sometimes too strict. For instance epoch or dev releases.
- calver. Possibly not the best for joplin, but worth mentioning.
So, I'd expect that, if the next release is going to be v2.0.0, the releases above would look like this:
- v1.8.5. Latest stable.
- v2.0.0-alpha1. Includes server support.
- v2.0.0-alpha2. More than server support.
- v2.0.0-alpha3. Includes android support.
- ... etc. You keep releasing alphas, then maybe betas or RC until v2.0.0 is finally released.
Also the alpha, beta and RC words say a lot per se about stability expectations.
