Spacebar click click click problem when searching
Hello, I'm using Joplin well.
By the way, a bug in use? I see the same thing
I want to know some solutions, but I don't know how to use this forum, so I'm posting here. Please understand.
version : 2.9.4 portable
system : windows 10 x64
[Symptoms]
If you enter a search term in the search box,
For example, if you want to search for Mars in the solar system,
If you enter the solar system and press the space bar, it has already changed to the search result screen without being able to enter Mars, so it is inconvenient to click the search window again.
I'd appreciate it if you could tell me if it's a bug or if there's something special about how to search (for example, if you search multiple words at the same time)...
It shouldn't do that in normal use, I was wondering if your issue is related to this issue but it seems like this should be in the version you are using.
See also: I have found some problems using Joplin search feature and In windows, search in all notes begins in the middle of the input · Issue #6333 · laurent22/joplin · GitHub
Thanks.... for reply...
