Some problems encountered when using the mobile markdown editor (beta)
When using list options and checkbox options on my computer, if I want to cancel, I can do it with a single click of "enter".
When I use the mobile terminal, if I want to cancel the above operation, I have to click "Enter" twice to do so, so that there is an extra blank line, and I have to delete it, which affects the layout feeling of the editing area. , although I know that doesn't affect the final result.
I have recorded android and windows screen videos for your reference.
My native language is not English, this review is generated by translation software, sorry for any grammatical errors.
Note: This behaviour change is a result of updating to CodeMirror 6 — this particular keyboard shortcut is built-in.
Here's why I think they made the change.
In the screen recording above, notice that
1. Test 1
2. Test 2
3. Test 3
Test4
1. Test1
renders as
As such, the blank line is needed to mark the 1. as part of a new list.
Additionally, if the extra blank line is not deleted,
the text on the line just after the list (Test 4 above) is included within the last item of the list!
Thank you for reporting this — it looks like other people find this behavior confusing!
(I agree that it would be nice if the extra blank weren't needed :slight_smile: )
:heart:Thanks, I see now, this seems like an advantage, after all mobile is not a double column.
