I'm trying again to use joplin and I need to synchronize on 3 devices. I started from scratch importing all notes 5importing a jex file). I then configured webdav synchonization. My network connection unfortunatly stopped during synchronization. I did select synchronization in FIle menu and it gave me the following message:
Created remote items: 2166.
Cancelling...
It seems that cancelling appeared at that time but I'm not shure. Does the synchronization option is a tooggle that enable/disable synchronization?
I'm lost again. I know I use pcloud and it has some problem but it's what I have available for the moment.
I did sync in a subdirectory called joplin that was initially empty. It stopped at 2166 synchronized of 11563 notes.
- version: joplin 1.5.14
- I use archlinux.
IN order to provide a log, I guesse I should start everything from scratch as exiting joplin during first synchronization has been said to be a bad idea.
