Side Menu of Notebooks, and All Menus Disappeared
File system
It was working just fine, I opened it one day and it is showing Notes or ToDo's from one Notebook.
The Menus to switch back and forth between Notebooks are gone.
There are no other links displayed, like settings, etc... There used to be an icon for settings, but no more...
If I type a Note Title into the Search Field it will find it, and tell me where it is, and if I click that link, it will show that Notebook and All Notes in it.
But it was easier to just View them and Click on them in the Menu Side Bar Area. I had it set to display one section with Notebooks and another displaying All the Notes in a chosen notebook.
Any Ideas how to get the menus or sidebar back?
Thank You!
CTRL + SHIFT + M toggles (show / hide) the main File Edit View Go ... menu.
F10 toggles (show / hide) the Notebook pane.
F11 toggles (show / hide) the Note List pane.
