I've been working to get Joplin Server (2.10.5) running via docker so I can sync notes on my home network. I've had some issues logging in (and thus syncing).
The biggest issue is that I can't connect to the server from Joplin on Android 13. Possibly related is that on my Windows 10 computer I can sync from Joplin portable, I can login to the admin ui from firefox, but not from librewolf.
I also made some changes to the docker-compose file, so here is that in case it is helpful. The compose and env files are separate files, but I aggregated the info here for ease of viewing: docker_compose_env_info (2.2 KB)
Thanks in advance for any help or guidance on where to start troubleshooting you can give
