Adding this as feature request since usability issue isn't necessarily bug:
The Joplin desktop app seems to zoom in when pressing ctrl+´
Joplin 2.6.0 (prod, linux)
from Flathub
Fedora 35 X11
^That key
I happen to hit that key combination accidentally quite often since I erase text with ctrl key. Figuring out how to unzoom the ui is extremely frustrating since the first logical thin is to press ctrl+shift+´ and then ctrl+alt+´ which won't work. For some reason, I happen to try out every possible combination with ctrl+shift and ctrl+alt but none of which will fix the issue
When you search on these forums, the first thing that pops up is changing font size using css, which wont fix the issue.
^That thread clearly instructs how to fix it, but it takes ages to find it when you don't know that such setting exists.
I don't (need to) understand why ctrl+´ zooms in. I will learn to zoom out after doing it few times but I spent about 40 minutes today trying to figure it out. For the first time in this month it took hours to fix. I'd therefore suggest binding ctrl+shift+´ or ctrl+alt+´ to default keybindings for zooming out, if you think that someone else than me will likely encounter the same issue
