After experiments with the font in the desktop app under linux , the appearance is disturbed. How can I reset it to the default settings?
Simply delete the hidden folder with the configuration joplin-desktop under ~ / .config.
The problem is that you will also delete all other Joplin settings by deleting the folder .config/joplin-desktop.
Just delete or update the row with key = style.editor.fontFamily in table settings:
- Close Joplin.
- Open
.config/joplin-desktop/database.sqlite - Do one of the following 2:
update settings set value = '' where key = 'style.editor.fontFamily'delete from settings where key = 'style.editor.fontFamily'
