Joplin 2.13.15 (prod, win32)
Hello Joplin Team,
I've been using Joplin extensively and appreciate its features. However, I'm missing a quick way to access Joplin, similar to global shortcuts in other apps. Is there a way to set up a global shortcut to bring Joplin to the foreground? If not, I believe adding this feature would greatly enhance productivity and ease of access for users.
Thank you for your hard work and for considering this suggestion.
muzak
17 February 2024 22:25
2
I agree, a native cross-platform solution would be nice to have.
Workarounds for Windows include using an AutoHotKey file and pressing Win + Joplin's pinned taskbar icon number .
also relates to this
The last essential plugin for my workflow which I rush a little bit to be in time for new year resolution. There are still a lot of plugins in my backlogs but they all nice-to-have features so I will not develop any of them soon.
Slash Commands is a collection of utility commands that can be executed by typing corresponding keywords, which start with a slash ('/'). Current version only supports two type of commands (string and datetime) but more might be added in the future.
[screencap]
You c…
for unix system, I made proof-of-concept plugin for espanso
An Espanso package named Joplin Shortcuts (or Jops) allows creating quick notes without the need to focus on Joplin window. It helps to streamline note-taking process and avoid disruption of your workflow.
Main features
:jop initiate the plugin: authorization of the plugin + setting up default notebook via external link
:mn make new note
:mt make new todo
:ct creating new todo from clipboard
How to install
Install espanso
in terminal run espanso install jops
Enable Joplin…
