Quick Note allows you to instantly open a dedicated note for capturing ideas, tasks, or reminders — either on startup or via a customizable keyboard shortcut (default: ALT+Q).
Capture ideas instantly with a dedicated Quick Note.
Desktop
Mobile
Open a Quick Note on Joplin startup.
Set any note as your Quick Note.
Open Quick Note anytime with Alt+Q (customizable shortcut).
Toolbar button for one-click access.
Easily unset the Quick Note when no longer needed.
Select a note → Tools → Quick Note → Set as Quick Note.
Quick Note automatically opens on Joplin startup (can be disabled in settings).
Press Alt+Q (or your configured shortcut) to open the Quick Note instantly.
To unset the Quick Note, use Unset Quick Note from the menu.
