Question re: importing tasks into Joplin
Dear all,
when I import a file with n Tasks into Joplin, will Joplin
  • create 1 note with n tasks, or
  • will I get n tasks in a notebook?
If all tasks end up in 1 note and I want separate tasks, do I need one md-file for each task?
If so, will the md-filename be used by Joplin as the task name?
If so, how do I code the "- " into the task name (or else tell Joplin that I am importing a task)?
Regards,
kai.
