Question about syncing with OneDrive
OneDrive
Hi everyone,
I just have a question regarding the sync with OneDrive.
I just noticed that my Joplin folder (in OneDrive > Applications) is shared via link (see screenshot). Translation of the screenshot: “Shared with: Everyone with this link. Editing possible."
I wanted to disable the shared link but it does not work. It just shows an error.
Is this the technical implementation of Joplins OneDrive sync or the way OneDrive works?
Greetings
Joply
It's definitely the latter and can't have anything to do with the way Joplin interacts with OneDrive. Sync takes place via direct API calls, not via browser-based file access and link sharing.
I don't know where the share originated and how it can be revoked, but I don't think there's a connection to Joplin as an application.
Ok, thanks :slight_smile: I thought so, just wanted some confirmation from other OneDrive users. So maybe there is someone here who can confirm this?
EDIT: If anyone has the same problem, I found the solution. I redid the configuration and now it works without being marked as shared. Seems like it was a bug.
