I can't open a note and the note has an hourglass icon next to it. What does it mean ?
Seems you didn't see this when you created the post.
- The version you are using. LATEST VERSION is not a version number!
- If it is a sync issue, please let us know what you are syncing with.
- If you report a problem with upgrading, please let us know both versions (from/to).
- If you report a problem with the editor, please tell us which editor you are using (WYSIWYG/Markdown).
- The operating system you are using.
If you can also please provide a log, as described here: How to enable debugging | Joplin
