Problem: Delete local data and re-download from sync target
Hi
Version:
Joplin 2.11.11 (prod, win32)
Profile Version: 43
Revision: 6886f6f
OS: windows 10 (client)
I use webdav on my debian homeserver to sync between laptops.
I reinstalled the server and moved the webdav folder to a new location.
Then had problems (double-copies of content), so decided to use: 'Delete local data and re-download from sync target'.
I get a message saying needs to upgrade target. But then receive this error (below). I waited a while, tried again, but still receive the error
Joplin upgrade in progress...
Please wait while the sync target is being upgraded. It may take a few seconds or a few minutes depending on the upgrade. The application will automatically restart once it is completed.
The full error was:
PUT locks/2_1_c999b6f25405443b869b74b20b737ebc.json: Unknown error 2 (500): <?xml version="1.0" encoding="iso-8859-1"?> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"> <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en"> <head> <title>500 Internal Server Error</title> </head> <body> <h1>500 Internal Server Error</h1> </body> </html>
Error: PUT locks/2_1_c999b6f25405443b869b74b20b737ebc.json: Unknown error 2 (500): <?xml version="1.0" encoding="iso-8859-1"?>
 <head>
 </head>
 <body>
 </body>
</html>
    at newError (C:\Users\zed\AppData\Local\Programs\Joplin\resources\app.asar\node_modules\@joplin\lib\WebDavApi.js:414:11)
    at WebDavApi.exec (C:\Users\zed\AppData\Local\Programs\Joplin\resources\app.asar\node_modules\@joplin\lib\WebDavApi.js:444:10)
    at process.processTicksAndRejections (node:internal/process/task_queues:96:5)
    at async FileApiDriverWebDav.put (C:\Users\u4073264\AppData\Local\Programs\Joplin\resources\app.asar\node_modules\@joplin\lib\file-api-driver-webdav.js:203:10)
Any help appreciated.
Thanks
