Preserve view / cursor position when switch between view mode and edit mode
Usually when looking for the right position for editing a note, intuitively I first scroll to the position in view mode and then press edit.
Unfortunately the edit mode jumps rigt to the top of the note for editing. So I have to look for the right position again.
This is very cumbersome since I have some really long notes that I am maintaining over years.
It would be better if the editor jumps to the position when the user pressed edit in the view mode.
Likewise, wehn leaving the edit mode and turning back to edit mode, it would be good if the view mode does not jump back to the top, but starts at the line where the cursor was last in the edit mode, or with the line that was the top shown line in the editable view.
It could of course made be configurable whether the position is preserved across mode switches or whether the view always snaps to the top.
Yeah, I also expect it preserve the view, or at least take you to the last cursor position.
Maybe the best approach would be an option that lets you choose desired behavior.
Unfortunatelly, this is a dealbreaker for me, as I switch between code and preview often, or have to find where I was at if switching from another note in which there were some information I needed for current note. This is most noticable on long notes.
I love this app and check for updates regularly hoping this will be implemented, thanks devs, keep up the good work :+1:
I think the problem is the double mode edit/preview.
I suggest developers to move to an hybrid approach, the inline preview, such that used in Abricotine (https://abricotine.brrd.fr/) or in VNote (https://tamlok.github.io/vnote/en_us/#!screenshots.md).
In this way you could also remove the dual-pane mode with all its problems, such as the right sync of edit and preview documents.
Isn’t that what the experimental WYSIWYG editor is trying to acomplish?
That is similar to how Typora does it, which also alows you to switch from code to hybrid seamlessly, which I sometimes do, and it works as expected.
Still, users may want to continue where they left off last time. Even after finishing reading/editing a note.
Well, the WYSIWYG editor is a rich text editor, so no markdown here and editor and preview coincide.
The way I proposed let you still write in raw markdown but you don’t have to jump from to editor to preview every time.
The topic of this thread is to preserve the cursor position if we switch between modes and if we switch between notes. If there is no mode switch in the future, fine. But switching between notes can always happen and I do it frequently
I'm still facing this issue in the 3.1.4 release. I think this is an UX bug. It's very annoying to have to scroll back to the line I was after switching from the view mode to the editor mode.
x2, I have some very long notes and when I need to go to markdown from WYSIWYG it positions the cursor at the top, then I switch back and top again.
Indeed. The cursor position should be saved for every mode and every note as you navigate the application and for when you open and close the application. You should never lose your place. This has been a very long desired improvement voiced many times by me. It seems this must be a difficult issue to resolve though, it has been partially and very imperfectly addressed with Resume Note plugin (it seems to only remember an approximation of position and it will not remember anything upon restart). Resume Note is imperfect, but it is a good start.
UPDATE: The Resume Note Plugin has been vastly improved to do pretty much all that I asked.
Someone just liked my previous comment. The Resume Note plugin mentioned above has been GREATLY enhanced and you can achieve pretty much precisely now what I wished for. I will add an update to that comment as well.
My real problem with this issue is using the Android version, and it says the Resume Note plugin is incompatible with Android Joplin.
Just released v0.3.0 of the plugin, which introduces mobile support.
Hi, I have the same request as OP. I think this should be part of Joplin core...
Ideally for me, in view mode, when you tap a place in note, it should open in edit mode on that location.
The plugin mentioned above implements something different - opening editor in the last edit location.
@Piotr How does this benefit over opening in edit mode by default, which is now possible in Joplin 3.6? This was discussed at length in Android: Default to view on open instead of last mode? and I see you already contributed to that topic.
If what you want is essentially full markdown rendering which you can then edit, it's a technical limitation, not a UI quirk. The note viewer, the markdown editor and the rich text editor all use different underlying technologies which currently have different levels of rendering support.
You can't make the view mode allow editing because the underlying technology is a viewer only. The way towards supporting full rendering and editing in place, would be to extend the available rendering features in the note editors
@mrjo118 on mobile:
  1. I switch between Markdown editor and Rich editor (because sometimes Rich editor is better and sometimes Markdown editor is better)
  2. I switch between Edit and View mode (because when I edit Markdown, sometimes I want to see how it looks rendered, and button to switch View/Edit is available in toolbar, and to switch to Rich editor, I need to go through "..." which requires more clicking)
  3. I have some old notes that were imported from OneNote, that use some funky tables with html/colored cells, and it said in the other thread that Rich editor may loose some formatting in such/similar case, so I don't want to enable it by default for all notes)
So even ignoring the 3rd point, as long as I use Markdown Editor, the "edit mode by default" won't help.
By the way, I just tested it:
  • View and Rich Editor are always synchronized
  • Markdown Editor always open in the same position (in weird position - not beginning, not last view/edit)
@Piotr In a change from the last few months, yes that is the case. But you'll notice that when you switch between those modes that altough the scroll position is synced, the contents don't look exactly the same after the transition.
So tap to edit wouldn't help. What you really want is for the view > markdown editor transition to sync the scroll position, it seems. That's a reasonable request, though I don't know how hard it is to do, and there is likely a reason why @personalizedrefriger didn't fix that too when he made the view > rich text editor sync scroll position change.
My point though is if you sync the scroll position of view > markdown editor, the result still isn't going to look exactly the same, and for that reason I think using tap anywhere to edit would provide a disjointed user experience
EDIT: I had a brief looked into this with AI assistance, and I think this is the reason why syncing the scroll position has not been implemented for viewer > markdown editor:
The rich text editor can sync with the viewer because they're both representations of the rendered document, so a scroll percentage is a reasonable approximation, and this is used to sync the scroll position. The Markdown editor is different because its document is the Markdown source, whose height often differs dramatically from the rendered output. The cursor position cannot used to sync the scroll, because the viewer does not have a cursor.
