Plugins are not working. (2 examples)
Joplin 3.0.13 (prod, linux)
Client ID: 4c34854f7ddf48ba95eba4b0849f5b64
i have installed 2 plugins to try.
1: ABC Sheet Music Plugin
after install and restart, i open a new sheet, type something like this:
K:F
!f!(fgag-g2c2)|
after that, nothing happens.
Plugin 2: Time tracking with TimeTagger.
After install and restart, 2 buttons appear in the upper right corner. “start” and ”stop”.
When i click on it... nothing happens.
Which editor are you using?
Which editor? i don't know what you mean by that.
i just using Joplin.
You can learn more about plugins by visiting Joplin Plugins.
For the ABC Sheet Music plugin, add "abc" after the first triple backtick like so: ```abc. If nothing happens, press Ctrl+L until sheet music shows right of your notation.
If the TimeTagger plugin doesn't work with TimeTagger running and plugin settings configured properly, note that here: Plugin: Time tracking with TimeTagger - Plugins - Joplin Forum.
Otherwise, you first need to self-host or sign up for TimeTagger, have it running, then configure plugin settings before trying to start the timer.
