External links working great. It opens them in the default system browser. Well done!
Internal links with your custom syntax joplin://<noteId> also work. But probably better to leave default joplin syntax for internal markdown links such just :/<noteId> ?
Hi @marc0l92
Is there any issues with the plugin?
I have some created diagram that are not rendering anymore. I checked the syntax, and it seems, the syntax is OK. In fact, these were rendered without any problem in the past.
Maybe there is any incompatibility with a new plugin installed or is related to this plugin itself. Let me know if there is any issue with the plugin, to avoid find out the problem in other place. Thanks.
I found the following error in the development tools log, that occurs when the plugin starts (go to the Help menu --> Toggle development tools and search for "plant").
joplin.plugins: Uncaught exception in plugin "com.github.marc0l92.joplin-plugin-plantUML": Error: ENOENT: no such file or directory, stat '/var/folders/z8/6_9tvj2d6931fmn5q64r1xjm0000gn/T/joplin-plantUml2-plugin/'
Once I created the missing folder and restarted Joplin, the rendering of diagrams was fixed.
Hi @johano and @shikuz
Thanks, I have already created the temporary folder in my Linux OS and diagrams are rendered again.
It will be possible to fix the plugin for creating this folder automatically in the future, if not exist, or at least adding this warning in some additional place, to be aware to future users at the time installing this plugin?
the same problem after update to ver 2.9.17,check the code and debug,find out the plugin onStart() event handler method phase。this phase invoke the clearDiskCache() method,the code linefs.rmdirSync(Config.DiagramsCacheFolder, { recursive: true }) will lead to this problem ,just comment it or try catch it,the problem is solved .
but i don't understand ,the same code ,previous joplin ver is ok,ver 2.9.17 not work
Hi - on mac desktop running Sonoma, I’m seeing a 403 in the development tools when Joplin tries to access the path to the rendered image. The images are rendering nicely, through online server or local picoserver. I can navigate there and see the rendered images, but some permissions are blocking joplin from allowing me to copy the image or path to image.
