Plugin: Auto show active note in sidebar 1.0.1 : breaks JOPLIN
Joplin 3.4.10 (prod, linux)
Device: linux, Intel(R) Celeron(R) N4020 CPU @ 1.10GHz
Client ID: de3faf1691004ef0982e9f2aac6cfe13
Profile Version: 48
Keychain Supported: No
Alternative instance ID: -
Revision: 85585d1
Backup: 1.4.3
Better Code Blocks: 2.0.1
Bulk Note Creator: 1.0.0
Emoji: 1.0.4
Favorites: 1.3.2
Freehand Drawing: 3.1.0
Home Note: 2.1.1
Hotfolder: 1.2.2
JSheets: 1.1.3
Note list (Preview): 1.1.0
Note list and sidebar toggle buttons: 1.0.3
Resume Note: 0.3.2
RevealJS Integration: 0.15.0
Tagging: 1.0.3
Templates: 2.4.0
Rich Text Editor
This plugin is now creating this issue (I know that because it stops when the plugin is deactivate) :
In the note list, when I double click on a note, it opens in its own window but disappears immediately. In fact the note window is under the main JOPLIN window. And it’s impossible to access to the window of the note.
Other thing : when I try to minimize the main JOPLIN window, it’s impossible !
It’s possible to minimize or maximize the JOPLIN’s main window again after accessing another program and going back to JOPLIN. But the window of the note is never accessible : always under the main one. Impossible to close the main window too (close button).
If I reduce a little the main window in order to see the note window, at this moment I still can’t have the note above the main window but I can close it and then close the main window...
