Performance issues on MacOS
macOS
Joplin 3.3.3 (prod, darwin)
Client ID: 72869785ca744aeea17f0824ec772c35
Alternative instance ID: -
Revision: 23254e6
Backup: 1.4.2
Joplin Cloud
I'm experiencing slow performance issues with the Mac app. There is an especially long delay when launching the app. I'm also noticing a significant delay when using the keyboard shortcuts to move focus to different areas, at least based on the spoken feedback from the VoiceOver screen reader I'm using.
Thank you for reporting this!
I'm linking to a similar issue reported by another MacOS user (also with the 3.3.3 pre-release): Joplin became unusably slow on MacOS after upgrade to 3.3.3 · Issue #11989 · laurent22/joplin · GitHub
Please try download the latest version from Downloading Joplin... | Joplin - that should give you a file Joplin-3.2.13-arm64.DMG which is specific for Apple Silicon. If not please report here
