macOS
Joplin for Desktop
Copyright © 2016-2024 Laurent Cozic
Joplin 3.1.20 (prod, darwin)
Client ID: 85bd61eaf4e4402f9438709fc3d881db
Revision: 8199362
Backup: 1.4.2
Inline tags: 1.3.0
OneDrive
Every once in a while, sync hangs on my desktop and just keep trying to sync. Clicking cancel does not help. Only solution is to kill Joplin and start again.
The main issue is that sometimes I don't notice, so I end up not syncing notes for days and can have conflicts.
Anyone has an idea how to solve it? Also is there a more reliable sync target?
This post might be related. If so, this issue may be fixed by this pull request.
For now, disabling sync locks may help (settings > synchronization > advanced > un-check "enable sync locks").
