Hey,
So while using Joplin I just found this bug: https://github.com/laurent22/joplin/issues/2865 so I put it on Github.
If the bug is not solved yet, I would love to solve it.
Hey,
on Mac OS 10.10.5 (Yosemite), I can drag the right border of the notebooks list with the mouse to set it larger.
See joined screen capture
Yeah but in my environment of MacOS Mojave I cant get the option to drag it.
Hi @betternote
Can you please try to unselect “Toggle Note List” and then try to drag and see if it works or not?
Maybe a better way to communicate about the issue is to directly comment here: https://github.com/laurent22/joplin/issues/2865
