Note has a checkbox - What's that?
[Newbie... sorry for the dumb questions]
Just getting started and noticed that one of my notes has a checkbox. Don't know how it got there. What is it for?
ALSO, I'm just starting to move from OneNote. I don't see a ENEX export option so cut & paste for 10+ years of OneNotes will be painfully slow. Any suggestions?
this is a ToDo where you can set a due date and for the set due date Joplin triggers a notification.
Create ToDo
Toggel ToDo / Note
Set ToDo Date
Got it. Thx.
ENEX is a proprietory format developed by Evernote. You could use Evernote‘s import options to access your OneNote data and then export as ENEX. On GitHub you can find a Markdown exporter for OneNote (MD is Joplin‘s native format), but that seems to be rather experimental to me.
It's been awhile since I used my Evernote account and I don't remember how to import from OneNote... and I can't find it on the interface. Help!
I deleted my Evernote account some time ago, but maybe this link could help:
https://discussion.evernote.com/forums/topic/113828-importing-from-microsoft-onenote-to-evernote/
I was looking at the web-based Evernote; found it on the desktop EN. Thx.
