My workflow with Joplin
Folks!
I'd posted some details about how I like to use Joplin for my note taking setup.
In case anyone's interested, this blog post How I take Notes has all the details :slight_smile:
Would love to know what you think about this and if there's any feedback for the same!
Cheers.
Thank you for sharing this detailed description of your note taking workflow. In your post you described the possibility of creating a script to rename exported Joplin files with their titles:
It can export notes in markdown/HTML format however the file names are all named with the id of the note (and not really the title of the note). I found this to be a bit of a drawback, however, one can quickly whip up a small Python script to fix this using the Joplin API.
Is it possible that you have already encountered a script like this?
Unfortunately, no. Haven't written this myself (yet).
