Move PDFs into Joplin
Joplin 3.5.12 (prod, win32)
Device: win32, Intel(R) N100
Client ID: 2d2b86f2ac6e4262a2081e4a3ff81a4f
Profile Version: 49
Alternative instance ID: -
Revision: 449555c
Backup: 1.5.1
Journal: 2.0.0
Rich Markdown: 0.17.1
YesYouKan: 1.1.3
I have a number of PDF documents I need to move into Joplin. Drag and drop just pastes a link, File Import does not offer PDF, Copy and Paste does nothing. Help, How do I move my PDFs?
I cannot duplicate what you are seeing. If I drag and drop a PDF onto a note (Markdown Editor) it imports the PDF and creates a link to it in the format:
[test.pdf](:/78b27876afce4a588a89b4a879f15d49)
If you want to import PDFs (and other file types) each into their own note, you could take a look at the Hotfolder plugin. Each newly created file in the hotfolder is automatically created as a new note. The files are added as attachments unless the file extension is defined as Add as text. After processing the files are deleted from the hotfolder.
