Is there a possibility to move the split of the editor/viewer? You can change with mouse pointer the width of notebooks-tabs-column, the notes column. But you can't change the width of the editor/viewer.
It can be done with CSS, see Split view column width
I already saw that post; that is about statically resize the editor-columns in userchrome.css (where after you have to restart Joplin to take affect...) Not really an answer on wat I want.
I want to change dynamically the column, just like the Notebook-column or Notes-column on the left side. When hovering mouse pointer on the splitline, chainging to resizer-icon, so you can click-and-drag the splitline to change the width of both editor columns. (See drawing)
resize: horizontal;
overflow: scroll;
in userchrome.css don't work.
Yeah I know what you mean, just saying as a workaround it is possible (hence the opening sentence on that other post). Otherwise this post is in the right place as a feature request.
Yes! please ![]()
Ditto.
I would like to have this option too.
