Version: Joplin 2.5.10 (prod, win32)
I'm an avid notetaker that's been using one note for many years. Decided to give Joplin a go. Appreciate if people can help me answer some questions.
Page Layout
I've used this layout for some time. Thoughts on the left and daily goals/to on the right. Can this be replicated in Joplin? I've experimented a little and it seems the only way is by using a two column table without borders? -
Line spacing for bullet points
I'm not allowed to have more images...
Can the spacing be changed? The gap is far too large
Example
- List item
- Can we use templates?
I'd use that that format daily. A saved template would be amazing.
Thanks all
