Microsoft Edge (chromium) Joplin Web Clipper extension
With the release of the new Edge browser based on Chromium, would it be possible to have the Joplin Web Clipper extension in the Microsoft Store ?
In the meantime, using the Chrome extension installed from the Chrome Web Store does work fine from my experience.
But installing it require to change an option in the extension settings:
I have no idea what the requirements are to publish an extension to the Microsoft Store.
If it’s as simple as it is for Chrome and Firefox, I don’t see a reason why not.
On the other side, since it’s possible to install it from the Chrome Web Store I don’t really see a good reason for getting it into the Microsoft store.
You can also try this.
