macOS
Joplin 3.2.8 (prod, darwin)
Client ID: a04eacd361f146d6a001afcf7debd419
Revision: d458648
Backup: 1.4.2
Favorites: 1.3.2
Freehand Drawing: 2.13.0
Inline tags: 1.3.0
macOS theme: 1.5.8
Note Tabs: 1.4.0
Quick Links: 1.3.2
Templates: 2.4.0
Rich Text Editor
Ive been using the rich text editor and switched to the MD editor to do something and now I can't switch back. Worse is that I can't navigate the MD editor at all. Cursor jumps lines and wont go where I need to go even when using the mouse. Is there a way to get back to where I was? Do I need to re-install and start over? Thanks.
