in the first line “exiftool” is green and becomes black if I change replace “.jpg” par “.JPG” ; in the second it’s black
in other lines the code is red.
I don’t really get the point.
Is there a problem with code integration ?
thank you
If you do not define what type the code is in a fenced block, i.e. where you start the markdown with: ``` on its own on a line, the interpreter will try to guess what needs highlighting.
@cyr06
my experience is that this forum doesn’t use the same markdown viewer, Joplin desktop’s one does a better job, but still not perfect for some code (and sadly the font is too feint for my eyes)
Thanks for that. Works a treat. However I needed a bit more, so played with increasing the number. It’s a pain to keep restarting Joplin to see result, would be nice if there was a redraw button within Joplin.
