Joplin is stuck.
I deleted it completely. Installed the program again.
But Joplin doesn’t work. The program window opens. But there are no reactions to my actions.
How can this problem be solved?
Macbook Pro. El Capitan 10.11.6
Joplin is stuck.
Ok, Laurent.
I will try it.
I reinstalled the program, pre-cleared the folder: c:\Users\YOUR_NAME.config\joplin-desktop
And everything works great. Thank!
