- Create a note with a list of many check box items.
- On Android and iOs it is easy to check of each item while scrolling down.
- On desktop this also works OK when we scroll up/down and check off items.
But when we use the “Layout” button to view the note in the main panel, the note jumps to the top each time we check a box. Then we have to scroll down manually to get to the “next box”.
Really bad explained, but hopefully you understand what I mean…
