Links in imported Evernote notes never work
Joplin 2.13.15 (prod, linux)
Profile Version: 44
Keychain Supported: No
File system
I imported my notes from Evernote (enex as MD or html) but internal (link from Evernote note to another Evernote note) did not work.
I tried
  • Just two new simple notes with the internal links (Evernote app link and Evernote web link)
  • "Old", complex and simple Evernote notes
  • Export as enex or html
  • Export with the current Windows App version
  • Export with Windows Legacy App
  • Export via Obsidian (where the links work!) - then open md files in Joplin
  • Import Joplin as MD or html
Did I make any mistake or is there any setting that I did not see?
Is there any way that Evernote internal links work? I really wanted to give Joplin a try, but if links in imports do not work, it's not an option.
Thank you very much for you help.
That's implemented in v2.14 which currently is in pre release
Thanks for the quick reply and the feature!
