Link-question (how do I add links?)
Dear all,
when creating links (e.g. abc.xyz) using the markdown-editor and the Hyperlink-button, I frequently end up with something like this: [] (abc.xyz); and of course this does not work.
In the WYSIWYG-editor & the Hyperlink-button, when adding the same link, I end up with abc.xyz, which does not work either (even produces an error message).
What am I doing wrong?
Regards,
kai.
Joplin 2.6.10 (prod, linux)
Client-ID: 3708fbfebb3646c787c57619e7200257
Sync-Version: 3
Profil-Version: 41
Unterstützter Schlüsselbund: Nein
Revision: 98fba37
In the first example you're meant to place some link text inside the square brackets. For example
[A really cool note taking app](joplinapp.org)
Renders as
As you can see, leaving the first part blank will make the link disappear.
Because you seem to be comfortable using links like ABC.xyz i would suggest you go into the setting under the markdown section and "enable Linkify" this will make it so that an old link is clickable in the rendered view.
I see. So the "Hyperlink"-box actually does not ask for a hyperlink but merely for what I want this hyperlink to be called ...
Thanks for pointing that out.
Cheers,
kai.
