Joplin version: 2.1.8 (prod, darwin)
OS: macOS 11.4
Hi, I recently started using Joplin on macOS. I've imported a lot of existing notes from a different application. I tend to use a separate line of tildes (e.g. "~~~~~~~~~~~~") as a division between sections of my notes. However, Joplin seems to be interpreting this as the beginning of a block of code.
I can't seem to find anywhere to disable this behavior, and I haven't noticed any documentation that this is intended behavior (and I thought blocks of code would normally be started with a sequence of back-ticks (e.g. "```"). Anyone know if this is a bug or is intended, and is there any way to change or disable this behavior? Thanks!
