Hi ![]()
I can't use a keyboard shortcut to zoom out.
Indeed, in the display menu, there is no shortcut for zoom out (Zoom arrière in French):
My keyboard is a Logitech K780.
I tried adding the line:
"command": "zoomOut",
"accelerator": "Ctrl+)"
to the keymap-desktop.json file, because the ) key is located between 0 and +, which work for reset zoom and zoom in, but it didn't work.
Do you know why and how to add a keyboard shortcut for zoom out?
I have Windows 10 and the issue is present on two different PC.
Joplin 3.0.8 (prod, win32)
ID client : 773c93d7dee04e1289cb896f235df6a3
Version de Synchro : 3
Version du profil : 47
Trousseau supporté : Oui
Révision : 826006c
Backup: 1.4.1
Bidirectional Links: 0.1.2
Favorites: 1.3.2
Note list and sidebar toggle buttons: 1.0.3
Note overview: 1.7.1
Note Tabs: 1.4.0
Outline: 1.5.13
Quick Links: 1.3.2
Rich Markdown: 0.15.0
Search & Replace: 2.2.0
Thanks ![]()
