Jumping to a section of a note from another note
Joplin 3.4.10 (prod, win32)
Device: win32, AMD Ryzen 7 5700U with Radeon Graphics
Client ID: ec934152e8ab441e8d1466e69798f9ff
Profile Version: 48
Alternative instance ID: -
Revision: 85585d1
Backup: 1.4.3
Search & Replace: 2.2.0
I have been trying to make the suggestion from @zimmer in this Support topic work, without success: Jumping to a section of a note from another note .
I want to jump from Note 2 to a specific location in Note 1. According to the advice in the above-referenced note, the following should work:
Note 1: [whatever I want to put here](#whatever-name-I-give-my-tag)
Note 2: [however I want to describe this link to tag in Note 1](“:/3a36db7b2cf442f881ece8824cfa0476#whatever-name-I-give-my-tag”) (please ignore quotes)
Does this just not work, or am I doing something wrong.
TIA for any suggestions,
Marian
Try this (ignore the \ symbols):
Note 1: [Whatever I want to put here]\(#whatever-i-want-to-put-here)\
Note 2: [however I want to describe this link to tag in Note 1](“:/3a36db7b2cf442f881ece8824cfa0476#whatever-i-want-to-put-here)
Thank you for responding.
What you suggest above seems the same as what I have been trying. Maybe there is some subtle difference that's not registering with me?
Exact thing that is not working (ignore the \):
Note 1: [Wraps]\(#wraps)
Note 2: [wraps]\(:/3a36db7b2cf442f881ece8824cfa0476#wraps)
The section marker in note 1 is set using a header. So if you have a header somewhere in the first note that is, for example,
## Important Information
You can access it from another note using the first note's Markdown link with the header text appended to it.
[Link Description](:/a99201ec48c74445a56e172d8757efae#important-information)
The appended section / header link starts with a #, is the text of the header in lower case, and any spaces are replaced by a hyphen.
Thank you! This works!
