Searching and Organizing Notebooks
How can I search, block, archive, or close notebooks effectively?
Is there a way to exclude large, archived notebooks from syncing to the mobile app, but still allow on-demand searching?
Notebook and Note Management
What is the best way to rename notebooks?
How can I align columns in note text without using tables (with tab stops or line alignment)?
How do I locate blank notes (notes with no content)?
What tools or methods exist to find and manage duplicate notes? Does deleting duplicates affect syncing or the note list integrity?
Keyboard and Navigation
How do I navigate the notebook list using arrow keys?
How can I quickly move among the search bar, note list, and note editor using the keyboard, without the tab key landing on extraneous UI items?
Editing and Formatting
How can I change the font size if there is no format board option?
How do I completely remove formatting from notes?
Attachments & Media
- How do I paste or attach .mp3 files (audio) into notes?
Web Clipper & Extensions
- How do I resolve web clipper errors on Opera (e.g., when “The Joplin extension/gallery cannot be scripted or installed on this browser”)?
Syncing, Backup, and UI Issues
I’m seeing a “cloud operation was unsuccessful” error when backing up Joplin notes to OneDrive. What could cause this, and how do I fix it?
Why doesn't the app remember the last window/screen position after restarting, and is there a workaround?
The plugins menu is greyed out on the options page—how do I enable or fix this?
