Jooplin Queries and issues
  1. search block/archive/close notebooks:
    • I have a large notebook of archived information that does not need to be searched on a regular basis and does NOT need to be synced to the mobile app on my phone, wasting space. How to search as needed?
  2. How to rename notebooks?
  3. How to simply align columns in text without a table (tab stops, previous line alignment)
  4. Find blank notes (no contents)
  5. Find duplicate notes:
    • If I use a tool to find blank notes and delete them from the folder where they are, will that cause Joplin to go crazy, or will it simply remove them from the list?
  6. Change font size - no option on format border, remove all formatting
  7. Web Clipper error, Opera (Chrome compatible): The Joplin extension is not available on this tab due to: The extensions gallery cannot be scripted.
  8. How to move between the search bar/note list and the note (only those 3) with the tab key/keyboard? It keeps stopping at other places I don't need, like the close X and the toolbars.
  9. How to navigate the notebooks list with the arrow keys?
  10. How to paste MP3 files into notes?
  11. How to back up the OneDrive folder for Joplin? Getting a "cloud operation was unsuccessful" on an MD file - how to fix?
  12. Why does the app not remember the last screen position when restarting?
  13. How to convert all enter keys to act like shift-enter?
  14. How can I make a key that takes me back to my home folder? Now I have to hit F10 and use the mouse to choose the default folder.
  15. The other issue is that I created a small new note in Joplin's main folder, and it still hasn't synced.
  16. If I delete some duplicates outside the system, will it affect the system? What will happen? Is it something I shouldn’t do? Is there an alternative? Also, what is the best way to find duplicates, empty notes, extensive notes, or to sort by size? What is the standard procedure?
  17. Joplin tab key stopped working in the editor and now jumps outside the editor - how to fix please? It was working yesterday.
  18. Unable to copy a tab key break from another line - how to do please? refers back to my question about simple text tables, fixed-width fonts, and smaller fonts - please help!
  19. there seem to be 3 different editors in joplin and i cannot tell which one i am using at any one time - where is the sign to tell you which editor you are using currently?
    * shows colored HTML and format elements (split screen left)
    * shows text formatted properly with no elements (split screen right).
    * shows plain text, no elements or formatting (single screen editor. i want to obviously use the one formatted correctly with no formatting elements, but i only see it in split screen. thanks.
  20. How to share a document with another person using only the regular version of Joplin? Is it possible?
  21. I want to ask, I wish someone could help me. I’m not getting complete synchronization; it’s missing notes that should be there, like in my old directory. I have newly created notes that are not syncing to my mobile device, so I’m unsure if they are being saved properly. I need a way to verify that. Also, one of my main issues is with these screenshots: many downloads are failing and can’t be completed. What’s going wrong? I used an app from GitHub that downloaded all the data from OneNote into MD markup files, and it should’ve imported everything, including images, but it did not. (PLEASE SEE THE UPLOADED SCREENSHOT)
Some of the questions have already been answered in previous threads you posted. Why do you keep on repeating the questions?
I apologize, it has been closed, so I had to report it again, all at once, under a support category. Don’t worry, I kept some of the answered questions. I’m also wondering if others would give the same answer as before. I also created different posts under the feature category, and someone commented that I should put all of them in a support category, so that’s what I did.
