I suspect this is a OneDrive issue rather than a Joplin issue, I am hoping someone else out there figured out an answer and can shed light on it.
- The version you are using. LATEST VERSION is not a version number!
2.88 Portable - If it is a sync issue, please let us know what you are syncing with.
OneDrive Personal - The operating system you are using.
Windows 10 21H2
I had to remove the VeraCrypt encryption on 2 data drives, one each on two computers. I decrypted both and all looks and works fine. Joplin works, Joplin Sync via OneDrive works, OneDrive works with other files syncing as well.
Since then I have dozens and dozens of lock files from the Joplin directory show up in my local PCs Recycle Bin. In fact all the deleted files from OneDrive now show up in the recycle bin. So this is obviously not a strict Joplin issue.
Besides turning off the recycle Bin for the entire data drive, has anyone else fixed this issue? Or is this just normal from now on? I have another computer that I left the Data drive encrypted on and it does not have these lock files in the Recycle Bin on it.
