Hi! Help me troubleshoot a problem. I am running 1.2.6 under Windows on two computers, and synch the data between them using DropBox. Computer A works find. DropBox synchs to both Computer A and Computer B. However, on Computer B, when I start up Joplin, the GUI never appears. The processes show a running Joplin process with 3 sub-processes using 20% of CPU. I am unable to provide more information about this error because the GUI never appears. I can't bring up the GUI to set any debugging options. The only differences that I can note is that the non-functioning Joplin runs under Windows 10 Pro while the functioning one runs under Windows 10 Home; also that the non-functioning machine is an HP machine while the functioning one is home-built.
What is my next step? Thanks for your help.
Joplin for Desktop
Copyright © 2016-2020 Laurent Cozic
Joplin 1.2.6 (prod, win32)
Client ID: 348634c19a984fbc80460ee0b23c7d45
Sync Version: 2
Profile Version: 34
Revision: f5f117cb (master)
