Joplin for Android V4
DESKTOP
Joplin 1.8.5 (prod, linux)
Client ID: 09f9ce4fefe64fc2860a9bbf6a58baeb
Sync Version: 2
Profile Version: 35
Keychain Supported: No
Revision: b28f087
TABLET ???
    Desktop: Linux mint 20
    tablet: Android 4.x
NOTE: I previously posted this as a Joplin failure using Android 9. I've now discovered, using Android app: Fake Device Test, that my device has been faked. It reports Android V9 but really has V4.x according to the test.
This android device was previously running Joplin perfectly for more than a year until I did a Joplin update several months ago. Since then when I try to start Joplin I get an android error saying it couldn't start Joplin.
Clearly the problem is entirely mine because the device is actually running Android 4.
I'm here with 2 questions that might save me from having to trash can the device:
  1. What was the last version of Joplin Android that was compatible with Android 4?
  2. If I can find and install that version, will it be able to sync with my master copy of Joplin 1.8.5 (prod, linux)?
Probably not but trashing a 10 inch tablet is not taken without examining all alternatives.
TIA
It's either 1.3.1 or 1.3.2
Probably not
You could see if the device was supported by LineagOS, and flash the tablet with a newer OS...
LineageOS – LineageOS Android Distribution
