Joplin crashes hard on Sonoma 14.2 beta
macOS
Copyright © 2016-2023 Laurent Cozic
Joplin 2.12.19 (prod, darwin)
Client-ID: c27e0fc6ec3147539c21d21215c38948
Sync-Version: 3
Profil-Version: 43
Revision: 7081046
Email Note: 1.2.2
macOS theme: 1.3.13
Dropbox
Whenever I try to resize the window Joplin crashes hard. I just tried a couple of times and the result is a crash every time. This is new to macOS 14.2.
Translated Report (Full Report Below)
Process: Joplin [78334]
Path: /Applications/Joplin.app/Contents/MacOS/Joplin
Identifier: net.cozic.joplin-desktop
Version: 2.12.19 (2.12.19)
Code Type: X86-64 (Translated)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-11-22 14:51:03.3074 +0100
OS Version: macOS 14.2 (23C5041e)
Report Version: 12
Anonymous UUID: AD0E17C4-56F5-D9DA-B323-5C0F432C4D48
Sleep/Wake UUID: 74FD0233-30DE-4401-A864-A4BDD8BB38F6
Time Awake Since Boot: 510000 seconds
Time Since Wake: 570 seconds
System Integrity Protection: enabled
Notes:
PC register does not match crashing frame (0x0 vs 0x7FF809381D0D)
Crashed Thread: 0 CrBrowserMain Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 4 Illegal instruction: 4
Terminating Process: exc handler [78334]
Application Specific Backtrace 0:
0 CoreFoundation 0x00007ff805b2eaae __exceptionPreprocess + 242
1 libobjc.A.dylib 0x00007ff8056245ff objc_exception_throw + 48
2 CoreFoundation 0x00007ff805a686cb -[__NSSingleObjectArrayI objectAtIndex:] + 269
3 Electron Framework 0x0000000114c2f79a _ZNK2v88internal11interpreter20BytecodeArrayBuilder5LocalEi + 201354
4 AppKit 0x00007ff809058297 -[NSView setFrameSize:] + 1461
5 AppKit 0x00007ff809068242 -[NSView setFrame:] + 347
6 Electron Framework 0x000000011b965b82 _ZNK4node13AsyncResource12get_async_idEv + 70475170
7 Electron Framework 0x000000011b92487a _ZNK4node13AsyncResource12get_async_idEv + 70208154
8 Electron Framework 0x000000011b93559b _ZNK4node13AsyncResource12get_async_idEv + 70277051
9 Electron Framework 0x0000000114c3cc1c _ZNK2v88internal11interpreter20BytecodeArrayBuilder5LocalEi + 255756
10 Electron Framework 0x000000011b93559b _ZNK4node13AsyncResource12get_async_idEv + 70277051
11 Electron Framework 0x000000011b92fd65 _ZNK4node13AsyncResource12get_async_idEv + 70254469
12 Electron Framework 0x000000011b92fc01 _ZNK4node13AsyncResource12get_async_idEv + 70254113
13 Electron Framework 0x000000011b92f988 _ZNK4node13AsyncResource12get_async_idEv + 70253480
14 Electron Framework 0x000000011b938646 _ZNK4node13AsyncResource12get_async_idEv + 70289510
15 Electron Framework 0x000000011b93559b _ZNK4node13AsyncResource12get_async_idEv + 70277051
16 Electron Framework 0x000000011b956a08 _ZNK4node13AsyncResource12get_async_idEv + 70413352
17 Electron Framework 0x000000011b93559b _ZNK4node13AsyncResource12get_async_idEv + 70277051
18 Electron Framework 0x000000011b95784d _ZNK4node13AsyncResource12get_async_idEv + 70417005
19 Electron Framework 0x000000011b93559b _ZNK4node13AsyncResource12get_async_idEv + 70277051
20 Electron Framework 0x000000011b9416c9 _ZNK4node13AsyncResource12get_async_idEv + 70326505
21 Electron Framework 0x000000011b938646 _ZNK4node13AsyncResource12get_async_idEv + 70289510
22 Electron Framework 0x000000011b93559b _ZNK4node13AsyncResource12get_async_idEv + 70277051
23 Electron Framework 0x000000011b9366e2 _ZNK4node13AsyncResource12get_async_idEv + 70281474
24 Electron Framework 0x000000011b94fe77 _ZNK4node13AsyncResource12get_async_idEv + 70385815
25 Electron Framework 0x000000011b95ebe4 _ZNK4node13AsyncResource12get_async_idEv + 70446596
26 Electron Framework 0x00000001195dfbb3 _ZNK4node13AsyncResource12get_async_idEv + 33226195
27 Electron Framework 0x00000001195d61a4 _ZNK4node13AsyncResource12get_async_idEv + 33186756
28 AppKit 0x00007ff8090761dc -[NSWindow _oldPlaceWindow:fromServer:] + 957
29 AppKit 0x00007ff809074bcf -[NSWindow _setFrameCommon:display:fromServer:] + 3033
30 Electron Framework 0x0000000114c33f29 _ZNK2v88internal11interpreter20BytecodeArrayBuilder5LocalEi + 219673
31 AppKit 0x00007ff809382ab5 -[NSWindow(NSWindowResizing) _resizeWithEvent:] + 2684
32 AppKit 0x00007ff80927ac1d -[NSTitledFrame attemptResizeWithEvent:] + 181
33 AppKit 0x00007ff80927a9d5 -[NSThemeFrame handleMouseDown:] + 298
34 AppKit 0x00007ff80930537c -[NSThemeFrame mouseDown:] + 30
35 Electron Framework 0x00000001195da699 _ZNK4node13AsyncResource12get_async_idEv + 33204409
36 AppKit 0x00007ff80920f3f1 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4580
37 AppKit 0x00007ff8091880c2 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 404
38 AppKit 0x00007ff809187d13 -[NSWindow(NSEventRouting) sendEvent:] + 345
39 Electron Framework 0x00000001195db33a _ZNK4node13AsyncResource12get_async_idEv + 33207642
Not sure if the crash log made it into the topic:
Joplin-2023-11-22-145111.ips (90.2 KB)
Apart from the fact that I would always first update the user application to the latest version (which may not help here), before I post such a serious problem ...
... I would surely remove all plugins including the macOS theme (which may not help either) ...
And then ask myself ... which was the latest combination of Joplin and osx (versions) in which the problem did not occur ? Example : osx 13.x.x and Joplin ???
Good luck !
Yeah, not my day today. Even if the new beta fixes the problems there may be others who update to Sonoma 14.2 with an older version of Joplin.
2.13.6 does not crash.
