Joplin closes after a few seconds
Dropbox
Rich Text Editor
Joplin closes after a few seconds, no error messages,nothing. It just closes
Can you post error messages from logfile? You’ll find it in your home directory as .config/joplin-desktop/log.txt
I don’t have that path in Windows..
I have the same issue. Win 11. Windows event log shows an entry every time Joplin window closes
Which error messages from the log file do you need Horvat?
it will be under C:\Users\YOUR-WINDOWS-USER\.config\joplin-desktop
I habe Joplin-desktop 3.4.12 installed.
based on one of the comments in this issue, you might try updating to the 3.5.4 pre-release:
Could anyone find a download for that 3.5.4 version?
This is a pre-release that you can get from here:
@cochabambinito, was that the first time you installed Joplin? Or was that an upgrade? And does it work with 3.5?
I may have the same error, but I know what it is, and have a workaround if so, here Joplin crashes shortly after launch
