Joplin Shuts down several moments of after start
Joplin 3.4.12 (prod, win32)
Device: win32, 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
Client ID: f3e8b8c637d84deb8175ffc512c7510e
Profile Version: 48
Alternative instance ID: -
Revision: e9a9f68
Backup: 1.4.3
Combine notes: 1.2.2
Enhancement: 1.2.1
Freehand Drawing: 3.1.0
joplin-excalidraw: 1.3.0
Link Icon: 1.0.0
Note overview: 1.7.1
Quick Links: 1.3.2
Resource Search Plugin: 0.1.2
Table Of To-Dos: 1.2.3
YesYouKan: 1.0.17
OneDrive
I launch Joplin, after aprox 10 seconds it closes itself.
Look at Joplin closes after a few seconds , could be the same issue.
Is that a new issue, after you upgraded Joplin or did you just start using Joplin?
If it's after upgrade do you remember which previous version you had?
I have been using for very long time. It happened recently. I thought it had something to do with the joplin extension in vs code, but i deleted it already. I don’t know if it is related to an update. I re-installed it - it did not help.
Do you remember if it happened after you upgraded the app?
