Joplin crashes after 30 seconds
Joplin 3.4.12 (prod, win32)
Gerät: win32, Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
Client-ID: 4f19c7bb2f834373a26a43b93682de27
Sync-Version: 3
Profil-Version: 48
Alternative Instanz ID: -
Revision: e9a9f68
Freehand Drawing: 3.1.0
Nextcloud
I think it started today, that Joplin crashes after about half a minute of run time. I already tried the secure mode, but it changed nothing.
Log file
-1768345956585.log (12.8 KB)
This may be related to Joplin's "auto-update" setting. If so, doing either of the following should fix the issue:
  • Upgrade to Joplin 3.5.11 from https://joplinapp.org/.
  • If it's enabled, disable the auto-update setting (settings > general > advanced > auto-updates, default state: disabled).
See also:
Worked like a charm, thank you! :blush:
