Joplin automatically creates a note backlinks with itself when creating a new note
Today I am aware at the moment creating a new note, automatically creating a backlink to itself, as showing the screenshot of the note.
As I have installed the automatic backlinks I also removed this plugin, but Joplin shows the same behavior after that.
I am not sure if this is a bug, a plugins problem, or if I have to set up something different, etc.
Please confirm to report it in github.
Using markdown editor.
Joplin 2.13.4 (prod, linux) Ubuntu 22.04
Profile Version: 44
Keychain Supported: No
Hey, have you tried restarting Joplin after removing the plugin?
Can you copy complete output of "about Joplin" to see what other plugins might be causing it?
Hi
Yes the issue disappear if I remove the plugin.
And finally I found the issue, if using Automatic backlinks to note I have to uncheck this option.
Screenshot from 2023-11-01 18-25-58
It seems that I unintentionally I checked this option before.
I have already unchecked it and the new note does not have the backlink.
