Joplin for Desktop
Copyright & 2016-2025 Laurent Cozic
Joplin 3.0.12 (prod, linux)
1D do cliente: 5e61222f52194256b47ee790fd60f37c
Versão Sync: 3
Versão do Perfil: 47
Keychain Suportada: Não
Revisão: a64d6e3
Backup: 1.4.1
joplin plugin app screen locker: 1.0.9
Joumal: 1.1.3
mMacos theme: 1.5.17
I want to know:
- It is possible to bring Vim as External Editor using Terminator?
- If yes, how to config?
I already read this topic Use Vim as external editor - Support - Joplin Forum and I know it is working with gnome-terminal.
But I try to mantain only Terminator installed as my terminal emulator.
This is my system specs:
OS: Debian GNU/Linux 12 (bookworm) x86 64
Kernel: 6.1.0-22-amd64
Packages: 3552 (dpkg), 40 (flatpak), 9 (snap)
Shell: bash 5.2.15
Resolution: 1920x1080
WM: i3
Theme: Arc-Dark [GTK2/3]
Icons: Adwaita [GTK2/3]
Terminal: terminator
CPU: Intel i7-3770 (8) & 3.900GHZ
GPU: AMD ATI Radeon 540/540X/550/550X / RX 540X/550/550X
Memory: 7881MiB / 11921MiB
Thanks in advance.
What did you try regarding Terminator?
You can practice attempts in a shell and run them from the command line. Once terminator and vim launch, you have what you need to move into Joplin.
Hello, andbenn.
- What did you try regarding Terminator?
Answer:
Path: terminator
Arguments: -- vim
and:
Path: terminator
Arguments: -e vim
- You can practice attempts in a shell and run them from the command line. Once terminator and vim launch, you have what you need to move into Joplin.
Answer:
From the command line, this one worked: terminator -e vim.
Path: terminator
Arguments: -e vim
But when I configure as above, Joplin does not open Vim.
In a terminal, type each of these lines:
which terminator
which vim
Each command will return the full path to the executable. Put that full line into the appropriate Joplin configuration text boxes.
Path: /usr/bin/whatever/somesuch/terminator
Arguments -e /usr/bin/whatever/somesuch/vim
As an example.
Hello, andbenn.
/usr/bin/terminator
-e /usr/bin/vim
After finding the directories and configuring them on, I took the test.
Both by pressing the shortcut Ctrl + e or by clicking the taskbar button, the external editor is not opened:
Do you need the -e? Try removing that.
I use st for my terminal and nvim as my editor and both launch with just the full paths and a ctrl-e sequence.
Not necessarily. When I used -e, I was just trying to apply a pattern that already worked in other cases. For example, to run musikcube using Terminator on my i3wm:
bindsym Ctrl+Shift+k exec --no-startup-id terminator -e musikcube
Returning to Joplin: I tried again without -e and unfortunately it didn't work.
